2023-12-07 8:07 AM
STM32H742/3 datasheet April 2021 DS12110 Rev 8 does not list a HRTIM specifications as e.g. STM32G474 datasheet DS12288 Rev 6 does in section 5.3.16 High-resolution timer (HRTIM). Please provide the data.
Best regards
2023-12-07 8:43 AM
Hello @Uwe Bonnes ,
Thank you for bringing this issue to our attention.
I will check internally and I will get back to you with more details as soon as possible.
Note that the latest revision of DS12110 is Rev 10 and it was published on 30-Mar-2023.
Thank you.
Kaouthar
2023-12-08 12:33 AM
Hi @Uwe Bonnes ,
I checked Internally and I found that no data are available for HRTIM on H7.
Could you please precise which characteristics do you need and for which purpose?
Then, I recommend you to contact your local FAE for some specific timings.
Thank you.
Kaouthar
2023-12-12 4:24 AM
Take e.g. data section 5.3.16 High-resolution timer (HRTIM) of the G474 as example.
