2017-03-08 6:13 AM
Everybody,
How can I disable :
#define __HAL_SD_SDIO_ENABLE_IT
without STM32CubeMX ?
Thanks
2017-03-08 6:24 AM
To disable the SD device interrupt you should use: __HAL_SD_SDIO_DISABLE_IT
You can refer to your cube firmware package to see their stm32xxxx_hal_sd.h/.c structure and get inspired from them.
You may refer to the working SD examples within your STM32cube, this will help you on your implementation.
Imen
