Custom bootloader and debugger issues
Hello,I am using an STM32WB with a custom bootloader, which is currently simple and only knows how to jump to a specific address to start the application. I upload firmware using debuggers (STLink V3 and JLink). When I upload the bootloader and the a...
JR2963 by Senior II
  • 3111 Views
STM32F373 Sigma Delta ADC: Filter Specs & FFT plots ?
Heyho,for a new project I need an MCU with 2 channels of 16bit / 50kHz ADC.It looks like the F373's sigma delta ADC (SDADC) might be good enough (it will be calibrated for accuracy anyway).But I haven't found any info about the SDADC's digital low pa...
LCE by Principal II
  • 1978 Views
STM32H730 with OctalSPI ISSI IS66WVO8M8 PSRAM
Hello community,I'm looking for some direction on how to setup the OSPI bus to communitcate with an external PSRAM part from ISSI - IS66WVO8M8 (datasheet attached). I've read through application notes and a handful of example projects but am having a...
taylors by Associate II
  • 3687 Views
Resolved! (some) example projects don't use *.ioc file?
E.g. the FatFs_USBDisk sample does not have a *.ioc file.Maybe not all example projects use STM32CubeMX?(the issue sounds like https://community.st.com/t5/stm32-mcus/creating-stm32cubmx-ioc-project-for-older-stm32cube-firmware/ta-p/49664)How can I en...
FBerg.1 by Associate III
  • 3492 Views
  • 7 kudos
Resolved! STM32H573 timer synchronization issue
Not sure why my previous post was marked as spam:Hello,I'm trying to do something relatively simple but can't figure out the issue. It might also be possible that there is no issue and my expectations are wrong about timer synchronization. I am using...
AHame by Associate III
  • 4786 Views
