STM32f429 +TFT 1024 x600
Posted on January 25, 2018 at 16:26Hello All I am sorry to disturb you all ; I am trying to fill the lcd structure with the right values but I think I have problem in understanding it please could you help me ? and I see that they are flickers on th...
Resolved! STM32CubeMX for STM32L4 Discovery kit IoT node (B-L475E-IOT01A)
Posted on September 21, 2017 at 03:47Hi,I would like to generate the code by using STM32CubeMX for STM32L4 Discovery kit IoT node (B-L475E-IOT01A).But I don't see the STM32L4 Discovery kit IoT node in the Boards List.Could you suggest for me?Thank y...
Good B by Associate II
  • 2481 Views
I use stm32fI 411, RTC coarse correction
Posted on January 25, 2018 at 11:54I use stm32fI 411, RTC coarse correction and everything works fine, but if main power is turned off and the RTC  is powered by battery, correction does not work, it should be so?#rtc-coarse-correction #stm32fi-411
WFI instruction causes system crash
Posted on May 21, 2017 at 18:30I am using a Nucleo L152RE for a simple interrupt driven application.I am using an external interrupt (EXTI0) and tim6 interrupt.Everything works fine but when I try to use HAL_PWR_EnterSLEEPMode (PWR_MAINREGULATOR_ON,...
STM32L162RCT
Posted on January 24, 2018 at 18:41I am david.I am going to use ST's stm32l162rct, but I am a beginner at it.What is the evaluation board for it?Best regards.
STM32F030RC CRC value wrong
Posted on January 23, 2018 at 03:59 I want to add crc function for the IAP-APP function. So I used the CRC example inSTM32Cube_FW_F0_V1.9.0 to test. But uwCRCValue is always 0. I think the uwExpectedCRCValue should be the last four byte (0x0803FF...
Resolved! Inverting PWM signal
Posted on January 23, 2018 at 21:51Is there a quick and clever way of inverting a PWM signal in software (I am using timer 2 of the Discovery Kit board/STM32L100)? Was looking for the complementary feature but I don't want a pair of PWMs, just the i...
e d by Associate II
  • 9176 Views
  • 11 replies
STM32F072 Nucleo STDIO
Posted on January 24, 2018 at 14:31Started with a STM32F072 Nucleo with Keil MDK using ST-Link of Evaluation board. Managed to do printf()/putchar() output to µVision Serial Debug (printf) Viewer via EventRecorder (DAP).But: How to get input (do no...
JuM by Senior
  • 2168 Views
