SPC570S50E1 UART Confinguration
Posted on March 29, 2018 at 10:06Hello Everyone!I am trying to configure LIN_FLEX_0 channel for UART communication. Following is my code for the configuration.&sharpdefine LIN_CH0 LINFLEXD_0LIN_CH0.LINCR1.B.INIT=1;         /* Put LIN into INIT mode ...
Thank you
Thank you in advance for your helpBest regards
Jessy J by Associate II
  • 2305 Views
DMA Write Issues with STM32L4R9-DISCO SDMMC
Posted on January 05, 2018 at 23:33The HAL_SD_ErrorCallback() is called EVERY time a one sector DMA Write is usedieSD_state = BSP_SD_WriteBlocks_DMA((uint32_t *)buff, sector, count); // With count == 1void SDMMC1_IRQHandler(void){ HAL_SD_IRQHandler(...
STM32CUBE F3 V1.10 CAN change?
Hello,Where I can find a list of change with this version about HAL_CAN. The compatibility has been broken but there is an exhaustive list of modification?ThanksBertrand
Icon View Widget problem
Posted on July 15, 2018 at 03:27Hi every body,I'm doing 1 menu icon (3-4 icon), using icon view widget.From .png image file to convert .dta, using BmpCvtST.exe in folder STemWin/software in stm32f7cube.If using image widget, .png files showed ok.If ...
Why program get into Endless loop at end of startup file?
I am working on stm32f205RBT. I have an IAP loader from ST from EVAL board that I made my adjustment. Loader works great on other devices with other adjustments. program goes to main after the loader like it should and works good until I'm trying to ...
ylor by Associate II
  • 4883 Views
  • 10 replies
Changing clock speed during runtime (64MHz to 1MHz)
Posted on April 11, 2018 at 22:57Hello, I am wanting to change the clock speed during runtime. I have an area of the code where I want to enter a lower power mode, shut down all peripherals, and wait for an external interrupt to occur. The specific ...
