measure VrefINT and VBAT onStm32f407vgtx
Hi allI am facing some issue related to measurement of VREFINT and VBAT which is IN17 and IN18 respectively,My ADC1 configuration is 12 bit resolution, 3cycles sample, one shot and software conversion.I ran few tests as follows1.vref which is 2.95 (V...
Ash1 by Associate III
  • 826 Views
Resolved! STM32H743VIT6 gets very hot @480 MHz
Hello all,I'm evaluating the STM32H743VIT6 on a third-party development board. I tested it with the system clock configured at 480 MHz (double checked everything, and all looks absolutely fine in terms of configuration). I did enable the "overdrive" ...
OpusOne by Associate III
  • 1038 Views
STM32G0B0REx RTC smooth calibration
Dear all, I'm calibrating the STM32G0B0RE RTC clocked by an external 32.768 oscillator using the following guide:https://community.st.com/t5/stm32-mcus/how-to-calibrate-the-stm32-s-real-time-clock-rtc/ta-p/744958Below is my debug code:int main(void) ...
STM32G431KB DAC DMA not working
Trying to get a basic sample DAC1 with DMA, triggered by TIM2 working. This should be trivial, works fine on SMT32F3. I'm using a Nucleo-32 SMT32G431.Using Cube IDE. The only non IDE-generated code in main is: /* USER CODE BEGIN 2 */   static uint...
PBieg.1 by Associate II
  • 33758 Views
  • 23 replies
  • 4 kudos
Resolved! STM32H523 hardware development problem
Greetings. I am a beginner and an electronic student and I am currently getting my hands on STM32H523. I have created a mcu board in Altium Designer just to control LEDs by GPIO, hopefully to understand more about STM32. I have the PCB fabricated, an...
