Resolved! STM32H503RB I3C private communication
Hi all.   I tried to communicate(private) with my I3C slave device using STM32H503RB board. To communicate with my device, I need to specify register address to write/read data. i.e. Frame = (Start with Slave ID w/ W=0) + (register address w/ W=0) + ...
GLee.16 by Associate
  • 3129 Views
CAN communication setup with stm32f407vet6
I have stm32f407vet6 board as well as another end for CAN is made using stm32f103c8t6, So can you help me setup CAN communication between these. where in stm32f103c8t6 will have usb end which will be connected to laptop.
SRath.4 by Associate II
  • 4443 Views
i2s PCM volume adjustment problem
I figured to increase the volume of the pcm data i just multiply it, because it is pretty much a sine wave sampled? I use this to increase the volume of the audio from the microphone connected to i2s and it works great. I do this when the audio is st...
TMich.1 by Associate III
  • 4343 Views
STM32H7 LSE Hardfault
I'm using external crystal for RTC on STM32H750VB. Sometimes when i powered up to board, its hanging on LSE initialization and entering hard fault. If i remove rtc backup battery and plug it again, its working. This happens very rarely :S I couldn't ...
Eralp by Associate III
  • 2758 Views
STM32F302R8 I2C1 Master Receiver. I2C_ISR_RXNE is not SET.
Im using STM32F302R8 and developing the driver for I2CMasterReceive data from Arduino.Here is my problem:After I send a command code, from master 0x51, and generate the start condition, the RXNE is SET. But, after it goes into the while loop, the RXN...
_legacyfs_online_stmicro_images_0693W00000biAUCQA2.png _legacyfs_online_stmicro_images_0693W00000biAUMQA2.png
WM_IR by Senior
  • 2186 Views
How to Unzip a zip file in memory?
I am writing a program to unzip a zip file downloaded from cloud in memory by itself if it seem any zip file available in memory but I am not getting any small & simple library to implement it.Can anyone help me regarding this?
SGoel.2 by Associate III
  • 4956 Views
