'register' specifier in Cube/LL
I have a bunch of following warnings:c:/programs/ARMtools/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F1xxxx/STM32F1xx_HAL_Driver/Inc/stm32f1xx_ll_gpio.h: In function 'void LL_GPIO_SetPinMode(GPIO_TypeDef*, uint32_t, uint32_t)': c:/programs/ARM...
Resolved! STM32G484 HardFault_Handler
Hi, I got stuck in the HardFault_Handler every time after editing some code. I'm using FreeRTOS in c++ combination with classes. First I thought this would be a memory issue. After increasing configTOTAL_HEAP_SIZE and configMINIMAL_STACK_SIZE, I was ...
ErX by Associate III
  • 539 Views
HAL functions using archaic terms - why?
Hi, I am compiling the STM32U0 HAL library and I get errors like this one:/Users/kiwanda/techniek/swexternals/STM32/HAL/Libraries/STM32U0xx_HAL_Driver/Inc/stm32u0xx_ll_comp.h: In function 'uint32_t LL_COMP_GetCommonWindowMode(const COMP_Common_TypeDe...
STM32F767ZI Custom Board with KSZ8081RND PHY
I have designed a custom board based on the STM32F767ZI MCU. To enable Ethernet connectivity, I integrated the KSZ8081RND PHY, along with the necessary magnetics and an RJ45 connector. You can find the full schematics in the attached PDF.On the hardw...
pp3reira by Associate II
  • 426 Views
