USBX Device CDC ACM problem
Hi all,I am writing to you because I am trying to understand how to make the USB CDC ACM work on the Nucleo U5A5ZJ board. First of all I analyzed some ST webinars and tested the UX_Device_CDC_ACM program which works correctly. I tried to reproduce it...
How to use SSD1315 Library
Hi!I'm trying to make a LCD screen work, but without success.I found this library:https://github.com/STMicroelectronics/stm32-ssd1315But I can'd find more documentation with examples (how to initialize).Can you give me a "wire"? Now I'm using a ssd13...
cyberpex by Associate II
  • 5142 Views
STM32 HAL Tick Timer - Handy Hint #3
The HAL tick timer interrupts the MCU every 1 ms. When using FreeRTOS it is best to set the HAL Tick source to a timer rather than the system tick interrupt.  Delays in freeRTOS are created using vTaskDelay() or vTaskDelayUntil() and don't use the HA...
Resolved! stm32f429ı_dısco not written sdram
hello i have stm32f429i-disco card. fmc settings are configured. i defined sdram in the linker file but variable sdram is not written. can you help me? i am using cubeide. my linker file is attached and i am attaching the photo of my fmc settings. my...
edramden by Associate II
  • 1928 Views
LWIP & FreeRTOS - code getting stuck
Hi allI am trying to make project on LWIP & FreeRTOS on STM32f407vgtx board issue what I am facing is when code is getting stuck and no task is hitting .I am sharing my project can you please check once .note: in task I am have called Lwip_Init in my...
Ash1 by Associate III
  • 1456 Views
