Power management
Strange description in datasheet of STPMIC1
In p. 28 of Datasheet - STPMIC1 - Highly integrated power management IC for micro processor units, 4.2.1, it says:3. Manually by setting VOUT[4:0] field of Table 38. BUCKx_MAIN_CR or Table 43. BUCKx_ALT_CR registers. Refer to Table 9. LDO output volt...
STNS01 specification
Hello, I am considering the STNS01 for a new project. The datasheet seems wrong. Is it possible to have power on SYS when starting with BAT, so with IN disconnected?How much is the maximum current flowing from IN to SYS?Thank you
lukin by Associate III
  • 646 Views
How to downlod the firmware of 3-phase Vienna rectifier with low cost mixed-signal control for power factor correction in microcontroller ? Please give all steps.
Hi,I have downloaded the firmware ("stsw-viennarect.out") for the 3-phase Vienna rectifier with low cost mixed-signal control for power factor correction from the ST's website.Could you please give me the all steps for download this firmware in micro...
KPate.8 by Associate
  • 897 Views
