Some problems about ism330dhcx
Hi, stNow I've found some new problems.​Sometimes the value read from who AMI register will be 0x48. After finding this problem, I suspect that the connecting wire is unstable. After replacing the DuPont wire, the value read back to normal (0x6b). I ...
6June.1 by Associate II
  • 6452 Views
Resolved! Using 'libiio' to read Accelerometer data from the IMU
 We want to use iio buffers to read accelerometer data. I tried the following, but it did not work. root@FAFUSION:/sys/bus/iio/devices/iio:device2# ls buffer current_timestamp_clock events in_accel_scale_available in_accel_y_raw mount_matrix of_...
ISM330DLC reading Registers failed Python
I am reaching out regarding an issue I am experiencing while reading register values from the ISM330DLC sensor using a Python script over SPI. Specifically, I am encountering incorrect data when accessing certain registers.For example, when reading t...
LT by Associate
  • 1061 Views
Resolved! X-NUCLEO-IKS4A1 with ST1VAFE3BX with MEMS-studio?
Hi. I have both the ST1VAFE3BX and the X-NUCLEO-IKS4A1 and I'm trying to read data from the biosensors using MEMS-studio, but I don't see how to get MEMS-studio to recognize the biosensors.  The documentation for the biosensors has instructions for w...
Rauscher by Associate II
  • 1725 Views
Resolved! HDPE triggering Tpresence for STHS34PF80
We are designing an STHS34PF80 into an occupancy sensor and the plan is to have an HDPE window to protect it.  To test the response in the actual product we purchased 1/16" (1.5mm) HDPE sheet and put it over the sensor.  The fresnel lens with the dev...
