Why i am not receiving a constant values?
Hello everyone!!!!I am using Motion_FX (9 axis) library in my application and receiving the values of Yaw, Pitch, Roll and Heading but these values, which i am receiving are not constant even if i kept the sensor in a fixed position values are varyin...
Anil3 by Associate III
  • 2414 Views
MotionFX yaw problem
Hi, I use LSM9DS1 in my project. I also use MotionMC and MotionFX libraries to calibrate the magnetometer and fuse data respectively and I have a following problem regarding the yaw output. The roll and pitch work flawlesly but the yaw output reading...
Pajaka by Associate III
  • 2023 Views
Resolved! LIS2DW12 VDD_IO current way too high!
Hey There, iam using a LIS2DW12 on a STEVAL-MKI179V1 eval board :https://www.st.com/en/evaluation-tools/steval-mki179v1.html#overviewhttps://www.st.com/en/mems-and-sensors/lis2dw12.html#overviewThe Datasheet says that it has 50nA standbycurrent and 1...
MSimo.1 by Associate II
  • 5682 Views
Pulsed IR transmitter doubt
 Hello.I had to interface an IR sensor for object detection and distance measurement but I'm using a normal IR transmitter and receiver and there's a lot of interference due to sunlight. So I want to pulse the IR transmitter and subtract the readings...
ASM330LHH didn't work in I2C with BLUENRG-LP
Here I used BLUENRG-LP SoC with ​ASM330LHH. We have the same schematic design in steval-IBD11V2A, like the first image. The second one is our schematic design.My I2C configuration init function is like:/** * @brief Configures the I2C interface use...
EPeng.1 by Associate
  • 2111 Views
