2024-02-23 10:23 AM
Is it enough to drag-drop the app from Application folder to thrash bin or is there anything else I should do?
2024-02-24 2:24 PM
Hello @ubaldot
Can you try the steps in the following forum post : Solved: Can't uninstall STM32Cube Programmer V2.5.0 from W... - STMicroelectronics Community
Otherwise, there is an unistaller .bat script in your installation directory
C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\Uninstaller
Tell me if ti answer your question, otherwise I will share with dev team !!
Best Regards,
Younes
2024-02-24 9:45 PM
Thanks for your reply.
However the suggested method won’t apply to my case because I am running on macos, as stated in the title. If you could share my issue with the dev team I would be grateful.
