2016-07-04 12:55 PM
Hello, is there any way to change the output dir (I guess it's the same as Toolchain Folder Location?) in CubeMX?
#cubemx-output-folder2016-07-05 6:53 AM
Hi choi.henry,
I will forward your request to our MX team.-Syrine-2016-07-19 1:48 AM
The project folder can not be changed. The workaround is to save the existing project as a new project: select the menu ''File > Save Project as'' and specify there a new project name (optional) and new destination folder.
Note this will create the project folder and save in there the project .ioc file only.
You will have to click ''generate code'' to retrieve the generated initialization code at the new location.
Best regards
