2026-06-01 6:23 AM
Hi all,
I am trying to upload code to a Nucleo-C031C6 but I can't select the right debugger or compiler to let the code compile and run. Below a list on what I did. I am new to STM chips but I programmed on other platforms before.
- Made a new project with CubeMX an selected board NUCLEO-C031C6
- Definied some settings in cubeMX regarding to clocks and pin settings and selected toolchain "STM32CubeIDE"
- Clicked on "Generate code" and selected a folder where to store my new project
- Connected the Nucleo-C031C6 to my macbook
- Launced STM32CubeIDE and imported the project folder that I just created
- I changed a bit in the main loop and wanted to build the project and here I got stuck. It seems that nothing is loaded to build the project or to debug the project.
Do I miss some drivers or settings? If I want to set a complier I just can't click any option, everything is greyed out. Also for debug configurations I can't browse or select a project. The debugger seems to have recognized the Nucleo board see attachment.
Thank you for your help!
2026-06-02 4:58 PM
Can you show the actual error messages from CubeIDE ?
2026-06-03 12:44 AM
Hi Pavel,
Thank you for your response, I found the issue. I forgot to first install the drivers when installing Cube IDE.....
You can close this ticket.
All the best!
