2018-11-16 6:47 AM
Does any one know that how to add OEM CANopen driver in to existing CubeMx+ARMMDK project.
History:
I have started project by using CubeMx to configure required pins and peripherals. It is working ok. Even I have configured required CAN pins using CubeMx. CubeMx is does generate HAL CAN related code. Now we have decided to use OEM CAN library. So do I have to remove MX_CANx_Ini call and use OEM CAN driver initiation code?
Has any one tried to mix HAL and OEM driver code in one project ?
If so then what should I take care of.
