  • 1756 Views
CubeMX and C++
Hi all,once again I stumble across CubeMX being so inflexible in its code generation.I use CubeMX to generate initialization code but I'm also using C++ and that's where CubeMX has major downsides.For example it is still not possible to tell CubeMX t...
EStei.3 by Associate III
  • 1608 Views
New CubeMX install on Ubuntu
Hi. Newby question about my STM32CubeMX (6.14.0) installation on Ubuntu. With the initial 'update', why do I get so many...:2025-03-31 14:17:40,313 [INFO] WebApp:194 - Connection lost2025-03-31 14:17:40,865 [INFO] WebApp:191 - Connection restablished...
LJB by Associate II
  • 3484 Views
CubeMX AzRtos Startup code Issue
Hello,Is it possible for ST to re-order the startup code in ST's implementation of AzRtos (CubeMX)?.  I think it would make everyone's life a lot easier if all the AzRtos services (ThreadX, FileX, NetX, USBX) start before the user apps/threads.Curren...
matt-crc by Senior III
  • 2173 Views
Resolved! STM32CUBEIDE Nested Project Library Path Problem
I am working on X-CUBE-AZURE in B-U585I-IOT02A board. My IDE version is 1.18 and i am using Fedora 41. When i enable FDCAN peripheral in CubeMX it places the stm32u5xx_hal_fdcan.c and .h file into the X-CUBE-AZURE/Drivers/STM32U5xx_HAL_Driver/Src. Ev...
erhangk by Associate
  • 1485 Views
