  • 1756 Views
Bug in STM32CubeMX with COMP
For COMP1 on STM32G0 here are the pin assignments from the reference manualI want PA1 and so I've chosen that in the STM32CubeMXHowever, the generated code sets and the value of InputPlus is  /** @defgroup COMP_InputPlus COMP input plus (non-invertin...
Carl_G_0-1750644467047.png Carl_G_1-1750644553274.png Carl_G_2-1750644605926.png Carl_G_4-1750644871312.png
Carl_G by Senior III
  • 1989 Views
Resolved! CubeMX STM32G0B1 ThreadX CMake
I created a project in CubeMX for STM32G0B1. I added ThreadX middleware. I chose "Add necessary library files as reference..." I generated a CMake project. It was good, it worked fine. After a few weeks of work and dozens of regenerations CubeMX leav...
varghamp by Associate II
  • 1876 Views
Resolved! STM32H562 SRAMx_ECC wrong description in CubeMX
HiWe work on a project with a STM32H562. We use STM32CubeMX Version 6.14 with the Firmware Package V1.5.0 to generate a STM32CubeIDE project on Windows 11. I just found a wrong description in CubeMX.The description for SRAM2_ECC, SRAM3_ECC and BKPRAM...
MMeie.3 by Associate III
  • 1678 Views
Resolved! STM32H562 configuring SRAM13_RST does not work in CubeMX
HiWe work on a project with a STM32H562. We use STM32CubeMX Version 6.14 with the Firmware Package V1.5.0 to generate a STM32CubeIDE project on Windows 11. I think I just found bug in the code generation of CubeMX.I could reproduce the bug below in a...
  • 1807 Views
STM32CubeMX PCC tool
I’m trying to understand the peripheral current consumption figures generated by the PCC tool in CubeMX for my STM32U031 based project but can’t correlate the generated numbers with the values given in Table 43 of the datasheet, so I’m wondering whic...
kswST by Associate II
  • 1085 Views
Resolved! UART mode enable missing
Hi @STTwo-32  & Community, This issue was reported a long time ago but I'm seeing something similar again now. In my case it's the definition HAL_UART_MODE_ENABLED for my STM32H755 project, this define being put into stm32h7xx_conf.h after each code ...
bramble by Senior
  • 1112 Views
  • 4 kudos
