  • 1759 Views
How to setup & use touch sensing with CubeMx
Posted on March 04, 2017 at 03:36hello. I am  luis.Recently I use stm32f051x touch sensing feature that setup touch sensing with CubeMx(the latest ver.).but after test touch sensing, I get touch sensing value only '1'.Searching St community, i have ...
luisfynn by Associate
  • 3518 Views
Resolved! CubeMX USB CDC VCP - Transmission problem
Posted on December 13, 2017 at 11:43hello,i am trying to send data to pc over the otg used as a virtual com port. The data is received with a terminal program (HTerm). In order to send data i am using the function CDC_Transmit_FS. For a basic test t...
Resolved! CubeMX - failure to install en.stm32cubel4.zip
Posted on December 08, 2017 at 21:56After CubeMX griped that my software was too old, I tried to upgrade from the New Libraries Manager, but there was an error downloading the file. I fetched the file manually, then tried installing using the New Li...
CubeMX -Uart interrupt work one time
Posted on December 10, 2017 at 11:16Hii'm config evboar  nucleo with CubeMX  the send  data work fine but  recive data with HAL_UART_RxCpltCallbacki's work one time and second time is stuck in  loop anddon't reach to HAL_UART_IRQHandler(&huart1) aga...
cubeMX Pin user label problem
Posted on November 10, 2016 at 16:01Pin user label disappears when I change the pin function in the cubeMX GUI. This is not an expected behavior, since the already given name of the pin has not changed. #cubemx
Bug report: STM32CubeMX 4.23 SD_initialize
Posted on October 26, 2017 at 13:12As I explaned inhttps://community.st.com/0D50X00009XkXviSAF, I have found another big error in the code generation of STM32CubeMX 4.23.In this case, the bug is related to FATFS + SDMMC. In my case, I am working wit...
In CubeMX (STM32F427) define two ports as GPIO_EXTI
Posted on December 06, 2017 at 19:03In CubeMX (ver: 4.23 mcu: STM32F427) I'm trying to define two ports PE10 and PB10 as GPIO_EXTI10 (I need to get edge interrupt on either one).However, in the 'Pinout' view, when I click GPIO_EXTI10 for PB10 and th...
Y CS by Associate II
  • 1685 Views
