  • 1756 Views
STM32CubeMX LL Driver Bug - HSE calculations
Posted on January 18, 2018 at 09:18Hello,I've encountered a bug in code generation when using the LL STM32F3 drivers 1.9.0 in Cube 4.23.0.The device is theSTM32F303CCTx, although it's probably not device specific.Using the clock configurator and set...
George.P by Associate III
  • 6544 Views
  • 12 replies
[Bug] SytemClock config with low layer and CubeMx
Posted on May 03, 2018 at 17:31Hi,There is a bug when generating clock configuration with CubeMx on an STM32F413RHT.The SystemClock_Config is missing a line before changing the PWR register (clock is not enable) :void SystemClock_Config(void){  LL_F...
nicolas b by Associate III
  • 1269 Views
Resolved! STM32CubeMx Training?
Posted on December 07, 2016 at 17:15Hi ST,You have this site: http://www.st.com/content/st_com/en/about/events/events.html/stm32cube-basics-online-course-with-hands-on-exercises-a.htmlHowever, I never received log-in details after registering for th...
hushel by Associate II
  • 7332 Views
  • 19 replies
Cubemx and IAR
Posted on May 02, 2018 at 22:51When I press the 'generate the source code' button in MxCube a window pops up that says 'Open Folder', 'Open Project', or 'Cancel'. In the past when I would click on 'Open Project' it would take me to the instance of t...
Change CubeMX
Posted on April 22, 2018 at 20:09Hello!After upgrading CubeMX to version 4.25In the * .bin code, did the path to the project come up?This is normal?#what-has-changed-in-cubemx-4.25 #what-has-changed-in-cubemx-4.25-from-cubemx-4.17
High frequency clock signal generation
Posted on April 16, 2018 at 23:34Hi,I'm facing a problem i can't solve. It seem so simple but i think i need an other point of view.For a project using a led driver (LED1642GW) i need a clock in 20MHz~30MHz.I forgot this oscillator in my hardware so...
0690X0000060AYIQA2.png 0690X0000060AJIQA2.png 0690X0000060AbpQAE.png 0690X0000060AcTQAU.png
STM32CubeMX 4.25 STM32L433RCTx SystemClock_Config Bug PLLM
Posted on April 11, 2018 at 11:48Hi guys.I'm working in a STM32L433RCTP based project.The code generated by the Stm32CubeMX for clock configuration has no value set for the PLL-M prescaler in the  PLL struct, see original code:----------------------...
H. K. by Associate
  • 3063 Views
