  • 1757 Views
Specific report from CubeMX
Is it possible to get from CubeMX a report with an additional column?I need columns:PERIPHERALS MODES FUNCTIONS PINS Pin Nbwhere 'Pin Nb' is an additional parameter. It will be easier to analyse PINs allocation.
MJani.1 by Associate
  • 2206 Views
STM32CubeMx is missing STM32L4A6VGT6P Device
Hello. I always cross reference my projects with STM32CubeMX software ( all up to date and new)https://www.digikey.com/products/en?keywords=STM32L4A6VGT6P%20But i can't find this device I am making my project on, did you forgot it ?Hope you can fix t...
Linas L by Senior II
  • 2171 Views
PWM Output on TIM3_CH1 not working
I started a new project using STM32CubeMX for a STM32F303VCTx, and used all the default options, and then configured the Timer3 for the all 4 channels as PWM ouptut (as in the snapshot).I open the project using uvision V5.26 and change the main.c onl...
Ala1980 by Associate II
  • 3468 Views
Can we use STM32CubeMX without Oracle JRE?
Hi,Since Oracle changed their licensing for their JDK/JRE last year, we have been using OpenJDK so that we do not need to pay for the Oracle release.The only time I have a problem with this on my computer is running STM32CubeMX and STM32CubeProgramme...
andyn_ff by Associate II
  • 2117 Views
[BUG] STM32G4 Use remap with encoder inputs
STM32CubeIDE v.1.3.0STM32G431RBTxIn any timer if the input channels 1 and 2 are set for use as "Combined channels = Encoder Mode" (by CubeMX or integrated in CubeIDE), it is not possible to select a remapped input (for example from the comparator). T...
