  • 1756 Views
Problem in NetXDuo when selecting RGMII mode in ETH1
I am trying to do tcp client application with stm32n6570-dk board and when  I select RGMII mode in ETH1, ethernet interface is grayed out in network interface settings in netxduo. How can I fix it? Cube IDE versiyon is 1.19.0, CubeMX version is 6.15....
erik71 by Associate II
  • 1001 Views
BUG FOUND IN LTDC 18bits mode in STMCubeMX 6.15.0
Hello ST team,I would like to report a pin mapping issue in STM32CubeMX when configuring the LTDC peripheral in RGB666 (18-bit) mode, especially on STM32H750 (and other STM32H7 devices).Problem descriptionWhen selecting RGB666 (18 bits) as the LTDC c...
deived10 by Associate
  • 683 Views
Keil slash and backslash
I generated an STM32 project using STM32CubeMX for Keil (MDK-ARM).In Keil, functions like HAL_GPIO_TogglePin() don’t show up in code completion (IntelliSense).I found that in Project → Options for Target → C/C++ → Include Paths, the paths use / (for ...
Resolved! STM32CubeMX generates wrong code for Nucleo-G431KB
In STM32CubeMX 6.15.0 / Win11 I generate a default CMake project for the Nucleo-G431KB board.The generated cmake/stm32cubemx/CMakeLists.txt contains:# STM32CubeMX generated symbols (macros) set(MX_Defines_Syms USE_NUCLEO_64 USE_HAL_DRIVER STM32...
KnarfB by Super User
  • 469 Views
CubeMX USB RTOS issue
      在32位中,字的单位应该要*4吧?为什么这里直接是按字节赋值???坑死我了 Translation: "In 32-bit, the word unit should be * 4, right? Why is it assigned directly by byte here? ? ?"   Edited by ST moderator to be inline with the community rules. In next time please write in E...
dxgvbsdfgsd_0-1756272017129.png dxgvbsdfgsd_2-1756272037356.png dxgvbsdfgsd_3-1756272048683.png dxgvbsdfgsd_4-1756272140038.png
Resolved! STM32_WPAN is grayed-out in MX
Dear STMicroelectronics Support Team,I hope this message finds you well.I am currently working with an STM32WB series microcontroller and using STM32CubeMX (version [insert version number]) for configuration.While setting up the project, I noticed th...
