  • 1756 Views
Resolved! STM32CubeMX MDK-ARM project generation failure
Windows 10 64bit - STM32CubeMX 6.0.1 - STM32H7B3LIHxQ MCUAttempting to generate a fresh project and get the below error. Any thoughts on how to resolve the issue? project file attached. Thanks!
Just Matt by Associate III
  • 4833 Views
MX Init functions overwrite static size_t variable
I am working on an embedded application using the STM32F103C8T6 (black pill). I've been slowly adding the functionality I need and adding different peripherals one by one. For USART I was using the excellent code written by Tilen Majerle here. Everyt...
SStru.1 by Associate II
  • 2074 Views
Resolved! Not seeing full DMA Initialization with CubeMx
With CubeMx, I've set up the DMA in Circular Mode, Data Width Half Word, Increment Address Memory. When I get the generated code, I only see the code below. Where are the other initialization parameters? Is it because the DMA channel interrupt is ena...
xpp07 by Senior
  • 1590 Views
STM32CubeMX bug preventing to use the LED output (PC13) on STM32F103/BluePill + bug in SVD file for STM32F103
I am using a Chinese low-cost "Blue Pill" board with an STM32F103C8T6, and developping in EmBitz IDE using init code generated by STM32CubeMX. On this board, the PC13 output is connected to an LED, but the code generated by STM32CubeMX will not allow...
Resolved! How do you install X-CUBE-Azure STM32Cube extension pack?
Hi,I am trying to install the X-CuBE-Azure expansion for STM32Cube. See expansion packages page: https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-a...
PSarr.1 by Associate II
  • 2187 Views
