  • 1756 Views
Resolved! CubeMX update Ubuntu responds 'Command not found'
We have CubeMX installed on Ubuntu 18, have been using it with no issues. We now need to update to 6.1.1 howver when enter SetupSTM32CubeMX-6.1.1.linux it responds with command not found. The file is the correct user with chmod to 777, we have tried ...
Darcy1 by Associate II
  • 1592 Views
How to configure 4-bit SDIO with DMA using STM32CubeMX?
How to configure 4-bit SDIO with DMA using STM32CubeMX, to write to an SD card?FW is running on an STM32F103.I am trying to set up an SDIO interface with DMA for an SD card using STM32CubeMX.The issue I am having is that I am unable to write to the S...
ard33 by Associate
  • 2868 Views
What is the correct default value for RCC_HSICALIBRATION_DEFAULT for STM32L431? It is going to be corrected in the HAL libraries?
Hi,I have an accuracy problem with the HSI16 of my STM32L431. It is really outside specifications, over 10% from 16MHz.I have discovered that during the initialitation of the RCC, the value of RCC_HSICALIBRATION_DEFAULT is 0x40, like in the datasheet...
RLope.2 by Associate
  • 1824 Views
