  • 1757 Views
No option to set OSR bit in SAI block with CubeMX on STM32H7
I want to use the oversampling feature in SAI block in STM32H742/743/750 device to set MCLK = 512*Ffs (sample frequency).There is the OSR bit in SAI configuration register 1 (SAI_ACR1) to enable this feature. But I cannot configure this feature with ...
AFroi.1 by Associate
  • 859 Views
Resolved! X-Cube-SMBUS middleware
Hi,I have downloaded the en.x-cube-smbus.zip package.How can I added it to the stm32CubeIde as a middleware?I have unzipped the file and moved the folder into STM32Cube/Repository/STM32Cube_FW_F3_V1.11.2/Middlewares but it is not seen by the stm32Cub...
lucobos by Associate
  • 2132 Views
stm32f746vgt6 sys timebase source tim problem
friends, I have a problem, can you help? I am working with the stm32f746vgt6 microcontroller. I came across something that had never happened to me before. I am using freertos. My crystal frequency is 25 Mhz. Whenever I select the sys timebase source...
mcizmeci by Associate II
  • 4318 Views
STM32CubeMX not setting the mcu when generating code.
I have a new pc with STM32CubeMX 6.1.1 and SW4STM32/OpenSTM32 IDE version 2.9.1.I created a simple project setting mcu to STM32L475GTx, activated a few pins and generated code. The project generated has no mcu selected. What is set up incorrectly in ...
PVall by Associate II
  • 4843 Views
Resolved! CubeMX and the latest CMSIS - how to?
According to this post:https://community.st.com/s/question/0D50X0000C0vEvBSQU/cubemx-cmsisdsp-include-problemsit should be possible to use the latest CMSIS (e.g. 5.7.0 from https://github.com/ARM-software/CMSIS_5/releases/tag/5.7.0) in CubeMX 6.1.1....
TDJ by Lead
  • 4394 Views
