  • 1756 Views
Can you change the location of generated files in CubeMX?
For a given project directory, is it possible to specify the folders in which files are generated into? For example, gpio.c is generated in PROJECT_DIRECTORY/Src and I would like to change it to another location (PROJECT_DIRECTORY/Src/MCU).The closes...
STM32CubeMX - new version with old errors
Hello,Few days ago I updated STM32Cube software to:   STM32CubeMX            6.2.0   STM32CubeIDE           1.6.0   STM32CubeH7 repository 1.9.0and I am struggling with old errors and shortcomings in the STM32CubeMX:When editing the "User label" fiel...
Resolved! STMPE811 undefined references to IOE
Hello everyone, I am using stm32cubemx to generate my project. In the ProjectManager/code generation option, I checked "Generate peripheral initialization as a pair of '.c/.h' files per peripheral". The reason was to turn main.c into main.cpp, so i w...
Xxoyo.1 by Associate III
  • 1188 Views
Resolved! Fail to get required STM32Cube firmware package
I have the firmware in suitable location: /home/mq/STM32Cube/Repository/STM32Cube_FW_L5_V1.3.1, while it prompted :Fail to get required STM32Cube firmware package, why?I used STM32CUbeIDE on Ubuntu 20.04
MQi.1 by Senior II
  • 1811 Views
Resolved! CubeMX 6.1.1 Fails to load project.
Hello,I am having a problem with CubeMX failing to load a project and not giving any description of what the error is. (See image)I started the exe using java to get more insight and I get this error2021-02-23 10:57:51,490 [ERROR] ThirdPartyModel:101...
SKILA by Associate II
  • 4574 Views
How to implement CMSIS RTOS v2 Task Notification
Hi all, I want to ask how to use/implement the FreeRTOS task notifications (https://www.freertos.org/RTOS-task-notifications.html)? I cannot find any of the CMSIS v2 API to use , even though I already enabled the USE TASK NOTIFICATION option in STM32...
  • 6421 Views
