  • 1756 Views
STM32F767 clock frequency configuration
Hi everyone,Using the STM32 -F767 board with freertos, and the CubeMX we are trying to change the clock speed via the clock configuration tab in order to lower the power consumption.After changing the HCLK to the desired speed (32MHz) or any other sp...
gsaru.1 by Associate II
  • 3379 Views
whats the use of PPS pin (ETH_pps_out) in Ethernet
Hi all,I'm working on Ethernet interface with STM32F417, I Generate the code by cubeMx for Ethernet stack (lwip).I want to know whats the use of PPS (ETH_pps_out - PB5) in ethernet because neither this pin is connected with phy nor ethernet port rf45...
VChau by Associate II
  • 5615 Views
MPU G0+
Hi community. I am planning to use memory protection unit (MPU) in my project. My MCU is STM32G031K8 but I cannot find how to activate this function with CubeMX. I would want to do the same as this example;https://community.st.com/s/article/how-to-co...
OAgui.1 by Associate II
  • 3972 Views
FreeRTOS + LwIP not working with last version of StmCubeMX
I am working with a STM32F429ZIT MCU based board with the LAN8742 interface and some LEDs. I am sure that the Hardware part works correctly because I use this card with a program made with STM32duinoI created a new project by changing only the follow...
MCord.3 by Associate
  • 1610 Views
Using FatFS with freeRTOS
Can you recommend me any link showing how to configure it in CubeMX and what I have to do to write and read the SD card. I have checked this https://controllerstech.com/interface-sd-card-with-sdio-in-stm32/ and it's working but no with freeRTOS. Not ...
DBrau.2 by Associate III
  • 6319 Views
what are you using for documenting code?
I want to get it right this time, once for all.My target would be future people (or me but balder) taking over my legacy code, so only technical medium exdperienced embedded programmers.Does anyone has experience doxygeing cubeMX generated code?i am ...
Javier1 by Principal
  • 4680 Views
Can't compile example projects from STUSB010 software library
Hello,I'm evaluating different solutions for USB Power Delivery and I wanted to try out STUSB010 software library. I downloaded the library from the official ST website (STSW-STUSB010 v1.3.0) and I opened a project on STM32CubeIDE 1.9.0 on a Linux ma...
AOliv.7 by Associate
  • 1811 Views
Any specific Reasons for PrvTaskExitError?
MCU getting into PrvTaskExitError while trying to acquire the semaphore using vTask Producer(after MCU run for Several Hours). Please find the screen shorts of the Fault Exception viewer and Callstack after the MCU crash. MCU: stm32f407VGT6Hardware T...
Hima by Associate
  • 4123 Views
