  • 1757 Views
Resolved! How can I "remount" an SD-card?
Hello.Short Story:I'm doing a little project that has to write some sensor data to an SD-Card.After setting up with CubeMX, I found this (well-known) example of "kiwih" (https://github.com/kiwih/cubemx-mmc-sd-card?fbclid=IwAR1JE_SkRHDFSikRvwptlszMZUA...
STM32CubeMX update
Hello, When Itry to open this file, I have this message. Do you know the way to update the version 6.9.1 for STM32CubeMX ? I don't know if I must update together with STM32CubeIDE version ? I have currently version 1.10.1 for STM32CubeIDE. Thank you...
DYann.1 by Senior II
  • 3861 Views
FatFS on SD card using SDIO in STM32F103
Hi,I'm trying to configure CubeMX to create a FatFS on an SD card using SDIO interface in STM32F103.I was reading https://community.st.com/t5/stm32-mcus/how-to-create-a-file-system-on-a-sd-card-using-stm32cubeide/ta-p/49830 but it's using SDMMC while...
AFink by Associate III
  • 4866 Views
Resolved! Register Showing
Does anyone know how to view the Registers in CubeMX while changing?If not, I think it would be nice to add a way.
Gedo by Associate II
  • 1394 Views
PI sampling period for FOC SDK
For calculating apriori PID parameters when running ST FOC SDK, you obviously need to consider the sampling time of the regulator for the integral term. According to UM1052, current sensing is synchronous to the PWM. Is the sampling period of the cur...
