  • 1759 Views
Resolved! Different build configurations for different ioc file
Hi,I am trying to find a solution to support different build configurations for the same MCU but different revision of PCB builds. PCB revisions could happen because of reassignment of pins and peripherals. I am using standalone version of CubeMX to ...
Confused about MPU region config for STM32H5
I'm trying to set up a MPU region to block out DCACHE from my SDMMC1 peripheral but I notice whenever a region is activiated in CubeMX, the "region start" field will not let me type any hex value in. Some red text below says that region start must AL...
devinw by Associate III
  • 1905 Views
Resolved! STM32H523 and AES HAL
Hi,I am trying to configure the AES accelerator on STM32H523 MCU. But I couldn't find an option to configure AES engine in CubeMX. I have double checked Reference manual and I found the AES engine in the MCU ref manual. I looked at the ST HAL and the...
hakeila by Associate III
  • 1560 Views
STM32H7 dual core support
Does ST publish a roadmap of features/enhancements for CubeIDE? I'd really like to know what is planned for STM32CubeIDE for the dual core H7 chips. For example, in Project Manager->Project, there is a setting "Dual Core Boot Mode", but it is greyed...
MMedv by Associate II
  • 4095 Views
Resolved! Systick configuration, STM32F4 Disc, FreeRTOS
I just started a new project with FreeRTOS on the board.When generating code via MX, there is a message about Systick configuration issue.The problem is, I cannot change the configuration about SYS and TIM.What can be the issue? What do I have to cha...
stefluik by Associate II
  • 1635 Views
Resolved! Trouble configuring I2C pins in CubeMx
Can someone please explain to me how this is even possible on the same device? They are the exact same device yet I can not seem to get the same pin config in different projects.The one project somehow got the PIN Layout where PB6(SCL) and PB7(SDA)...
table by Associate II
  • 1541 Views
