2023-04-03 11:45 AM
I downloaded Cube Power Monitor and am trying to use it to connect to the LPM01A. I have downloaded and installed the W8 version of the virtual com port driver.
I can select the board in the drop down menu, but when I hit "Take Control", a dialog box pops up with the message `error pwr get`. When I hit okay, another pops up with the message `Get current range command failed` with another message below it `ERROR TIMEOUT`. Hitting ok again gives yet another dialog box with the message `Board has been released due to connection issue. Please unplug and plug the board`.
I've tried unplugging and plugging it back in and the same thing happens. I am currently on Windows 11, but I've tried on a different windows 10 machine and the result was exactly the same.
Any help would be appreciated.
Please also take a look at my other question for something that might be related... having lots of issues with this board so far...
2025-03-05 1:25 AM
Same for me. v1.2.0 kept throwing error. When I used 1.1.1 of graphical tool then it worked. ST never works straightaway out of the box.
2025-03-06 5:12 AM
Hello @PPa
Can you give more details about the STM32PowerMonitor errors.
Which version of STM32-LPM01-XN firmware are you using? You may updated in following link.
