STM32CubeMonitor (MCUs)
Ask questions on STM32CubeMonitor. Discuss the latest updates, including specialized versions (power, RF, USB-PD).
STM32CubeMonitor-1.12.0 is available
Hello The version 1.12.0 of STM32CubeMonitor is available on st.com :  https://www.st.com/en/development-tools/stm32cubemonitor.html What are the main changes in this version ? Node-RED® updated to version 4.1.3.STM32 devices list updated.Software de...
STM32CubeMonitor-RF V2.19.0 is available
Hello A new release of STM32CubeMonitor-RF is available on st.com. Click on "Get latest" to download the version 2.19.0. What are the main changes in this version ? Alignment with STM32CubeWB firmware 1.24.0.Alignment with STM32CubeWBA firmware 1.8.0...
Resolved! Is it possible to output graph for multiple data-buffer?
Dear Expert,I could view an array-buffer thanks to "https://community.st.com/t5/stm32cubemonitor-mcus/how-to-watch-an-array-using-stm32cubemonitor/td-p/225086/page/2"Following flow is my test-flow blocks. Cube-array block was referenced from above li...
Tiel by Associate II
  • 1770 Views
ULPMark™-CoreMark score
We were following the ULPMark™-CoreMark User Guide for getting the ulp mark score but the STM X-NUCLEO-LPM01A is always throwing up some error and the LD2(ErrorLED) turns on causing issues. Also if in the case it runs its always telling    “>! Valida...
Abhilasha by Associate II
  • 2656 Views
STLNK-V3PWR Communication With Python
Hi Is there a way to communicate with the STLNK-V3PWR to extract current consumption?  (the Acquisition & Replay output).  I would like to communicate with it via Python (or other language) to automate current consumption measurements? Thank you.Pete...
PK3 by Associate
  • 1320 Views
Resolved! Setupstm32cubemonitorpower crash
Hi, I'm using a fresh debian testing (12) and when i try to launch "SetupSTM32CubeMonitor-Power.jar", i get the error :Command line arguments: SEVERE: java.lang.ArrayIndexOutOfBoundsException: Index 70131 out of bounds for length 22674Debian is not...
Frog by Associate III
  • 3321 Views
Resolved! STM32CubeMonUCPD fails on launch
Hello,I'm running ubuntu 24.04 and running STM32CubeMonUCPD with "jara -jar SetupSTM32CubeMonitor-UCPD.jar" fails with error  Command line arguments:SEVERE: java.lang.ArrayIndexOutOfBoundsException: Index 70131 out of bounds for length 22674This same...
vddvcc by Associate
  • 2255 Views
Unable to select SRC PDO
Hi,I am using a custom board based on STM32G4. I have successfully generated SINK code using cubemx and testing it using UCPDcube monitor. Explicit contract has done correctly but unable to select a source PDO. PFA, trace, and screenshot.  I apprecia...
RJain.1 by Associate III
  • 1623 Views
