2021-02-24 7:00 AM
STM32CubeIDE 1.6.0 was released this week on st.com as well as a in-tool update patch.
Caution: The in-tool update does not allow updating drivers and ST-LINK server tool. Full installer is required for this.
What is new in 1.6.0? (only some highlights)
Main issues fixed in STM32CubeIDE 1.6.0
Only a sub-set of the many tickets closed are mentioned in the release note.
Known problems and limitations
Please refer to the release note.
Where do I Obtain CubeIDE 1.6.0?
2021-03-02 1:11 AM
Hello Anguel!
Could you send me the workspace log? It's located at $workspace/.metadata/.log
2021-03-02 4:43 AM
I just updated my CubeIDE from 1.5.1 to 1.6.0 and now when I try to generate code with the device configuration tool in an STM32 project, the IDE is not responding. After restarting CubeIDE the perspective changed, I had to reset it, but I still cannot generate code. The UI of the device configuration tool is changes everytime I restart CubeIDE.
Also I cannot revert to 1.5.1 because it gives me an error.
An error occurred while collecting items to be installed
session context was:(profile=STM32CubeIDE, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.ecosystemintegration.stinsider,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.ecosystemintegration.ui,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.mx,6.1.1.202012091304
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.mx.stinsider,6.1.1.202012091304
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.projectcreation,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.projectcreation.ui,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.common.feature.utils,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.common.services.adapted,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.common.services,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.common.services.mx,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.common.ui,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.common.utils,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.documentation,1.5.0.202011131254
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.analytics,1.5.1.202012101225
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.build,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.build.ui,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.buildanalyzer,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.converters,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug,1.5.0.202011100858
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug.jlink,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug.openocd,1.5.0.202011091203
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug.sfrview,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug.stlink,1.5.0.202011170830
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.debug.swv,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.cubeprogrammer,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.gnu_arm_embedded,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.gnu_tools_for_stm32.7_2018_q2_update.bin,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.gnu_tools_for_stm32.7_2018_q2_update,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.gnu_tools_for_stm32,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.jlink,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.openocd,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.externaltools.stlink_gdb_server,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.freertos,1.5.0.202011161802
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.ide,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.informationcenter,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.linker,1.5.0.202011051335
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.linkerdb,1.5.0.202011051335
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.p2,1.5.0.202011131318
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.productdb.debug,1.5.0.202011051456
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.productdb,1.5.0.202011051456
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.projectnatures,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.projecttree,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.rcp,1.5.1.202012101225
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.resources.common,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.resources.extended,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.stackanalyzer,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.startup,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.targetadapter,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.toolchain.arm_none,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.toolchain,1.5.0.202011041201
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mcu.toolchain.ui,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.debug,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.debug.openocd,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.ide,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linker,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linkerdb,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linux.debug,1.5.0.202011161402
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linux.ide,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linux.projectcreation,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.linux.toolchain,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.productdb.debug,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.productdb,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.projectnatures,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.projecttree,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.remote.ssh,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.resources.common,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.resources.extended,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.startup,1.5.0.202011040924
No repository found containing: org.eclipse.update.feature,com.st.stm32cube.ide.feature.mpu.targetadapter,1.5.0.202011040924
2021-03-02 5:48 AM
I misread the message the first time. Hence the edit.
Anyway, before trying anything else I would re-install the full CubeIDE package. Hopefully that will probably solve the problem assuming it is he upgrade that failed in the first place...
2021-03-02 6:37 AM
2021-03-02 8:08 AM
I uninstalled 1.6.0 and installed 1.5.1 and it worked fine. I updated to 1.6.0 and it didn't work. I uninstalled 1.6.0 and installed it directly and it didn't work.
2021-03-02 8:53 AM
Can't update:
No repository found at http://sw-center.st.com/stm32cubeide/openstlinux/updatesite1.
2021-03-02 9:11 AM
Could you Reload all sw-center.st.com urls listed in Preferences > Install/Update > Available Software Sites, and paste here any errors?
If all reloads succeed then retry to update with Help > Check for Updates
2021-03-02 9:17 AM
Looks pretty annoying indeed...
What is your OS?
Also could you share you workspace log file workspace/.metadata/.log to see if something guides us to the root cause?
2021-03-02 11:43 AM
Hello! After the update, the configuration of old projects does not work !!! The program hangs, I do not know how to fix this error. The project is blocked, trouble! Please, help.
2021-03-02 12:57 PM
@Julien D_OEHAUDT I made the package manager to see the 7-2018 package by installing as "Local" (pointed to existing directory under plugins).
Sorry don't have time for toolkit management. Debugging makefile projects has higher priority for me because our customers need it. [see this thread]
All other issues are minor.
-- pa
