2021-05-05 7:15 AM
The eeprom I am using has no status byte/bit. In order to know if the device is busy you have to look for an ACK when repeatedly sending the address byte.
I cannot find an easy way to do this using the CUBEIDE and the HAL. All the low level i2c routines are static to the libraries.
Any ideas?
Thanks
Rich
2021-05-05 7:20 AM
The ACK in I2C is a part of the protocol. Every HAL I2C routine that sends data will check for it.
The HAL_I2C_IsDeviceReady routine in particular does this.
2021-05-05 7:20 AM
2021-05-05 7:24 AM
Ugh, right in front of me. Thank you
Rich
