2026-02-08 6:15 AM
Hi, so the recent change to make CubeMX a separate app has broken my old project. I am using a Nucleo board and HAL in the project. After a change to the .IOC file I get "stm32h7xx_nucleo_conf.h:50: warning: "USE_NUCLEO_144" redefined".
Is there a resource somewhere explaining to to do all of the after the CubeMX split?
2026-02-08 6:36 AM
Remove USE_NUCLEO_144 from the preprocessor defines in project properties.
Or ignore it, since it's not preventing compiling from working.
This was an issue before the split as well.
2026-02-08 6:36 AM
2026-02-08 6:53 AM
Thanks for the response. I'll try it, but a have to point out it worked fine before the split.
2026-02-08 7:09 AM
That did it! Thanks so much!
