STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
STM32F415 SDIO + STOP Mode
I am using an SD card with STM32F415. The MCU periodically enters STOP mode.Currently, I observe the following behaviour in the IDE related to SDIO:- Before enabling SDIO for the first time, the current consumption in STOP mode is as expected (around...
MZadn.2 by Associate II
  • 752 Views
Resolved! Login issue within the IDE
Hey all, first and foremost I'm new to the embedded systems space, I've been trying to get my feet wet with a hello world project but for some reason with Cube 1.17.0 I'm missing the "MyST" login tab at the top of the screen. I've tried Re-installing...
JB_Dev by Associate II
  • 6806 Views
  • 11 replies
  • 6 kudos
Target unknown error 32 with STM32N6570-DK
Hi everyone, I am trying to program my board but suddenly I am getting Target unknown error 32 Error in initializing ST-LINK device. Reason: Unknown. Please check power and cabling to target.this error. I tried connecting my board with STM32CubeProg...
STM32CubeIDE 1.15.1 Not Generating Code
I have an STM32G474 project that has been working for some time but the latest update doesn't generate code from the .ioc config GUI.If I make I make changes in the editor and select generate code, the pop flashes quickly and goes away but no code ge...
DamageG by Associate II
  • 2563 Views
Resolved! CubeIDE "crash" after few moments
Hi All,I started to have issue with CubeIDE. It "crash" / "close itself" after few moment after startup. Log is attached. I have tried this:Uninstalled CubeIDE 1.18.1 and I have done clean install 1.19.0, without successI have created new workspaceI ...
JDosp.1 by Associate III
  • 1154 Views
Resolved! SystemCoreClock vs HCLK vs APB1
I am learning to use the PWM Input mode to measure input frequency. I am using examples from the internet to help me along.In my .ioc file SYSCLK is set to 8MHz and with a prescaler set to /8 my HCLK and APB1 are set 1MhzIn the examples I studied in ...
xuraax by Associate III
  • 1831 Views
"There is no active editor that provides an outline"
Hello everyone, I am on Windows 11 and am using STM32CubeIDE version 1.18.0 (also tried on verison 1.18.1). I have logged into myST within the software as well (through Help->STM32Cube Updates -> Connection to myST). I can edit the pins in the .ioc f...
deta by Associate III
  • 3353 Views
STM32 compile process size
Hi everyone.I've got a question about a strange aspect of my project and the compiling process.I have some files to be compiled for my project. The compile process goes fine, everything is correctly compiled and looking both on console output and bui...
zioMorgan by Associate II
  • 1156 Views
  • 4 kudos
