2025-07-07 11:29 PM
Hi All,
I started to have issue with CubeIDE. It "crash" / "close itself" after few moment after startup. Log is attached. I have tried this:
Thank you for any advice
Regards,
Jan
2025-07-08 12:01 AM
Issue solved. There was a pending update for the CubeMX software. It seems this somehow interfered with CubeIDE. After startup of CubeMX and finishing update, CubeIDE works properly.
Jan
2025-07-08 12:01 AM
Jan
2025-07-08 12:37 AM
> I have disabled checking updates in CubeIDE, but without any success
The log shows update attempt. So disabling update did not work. Try to disconnect from network completely, then reinstall.
2025-07-08 12:41 AM
Yes, I this tried also. It seems updater from CubeMX somehow broke CubeIDE. Reinstall did not fix issue as I said.
Jan
2025-07-27 3:18 PM - edited 2025-07-27 3:19 PM
Had similar issue. Uninstall CubeMX from system fix problem.
