STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Resolved! Has anyone got ITCM working with GCC under STM32CubeIDE
Hi,I have spent three days trying to put some real-time FIR filters into ITCM to speed things up.I have been able to allocate the functions, copy the code from flash to ITCM in the start-up file, but when I run the system the ITCM memory gets changed...
Why does sprintf not work with RTOS?
I'm trying to use this function:char str[80]; float val;   sprintf(str, "%f", val);But the task freezes.I've already added the -u _printf_float flag to work with the serial output, but it still doesn't work.If using another form of variable, %d, %u, ...
by Not applicable
  • 1987 Views
Resolved! [SOLVED] Undefined Reference to custom Static Library
Hi,With supply issues currently, I have been working on 3 different micro controllers of the same family, STM32F4xx. I am trying to contain the hardware specific code in their own projects, 3 each for the processors. But I have common code that is us...
JNoon.1 by Associate III
  • 9660 Views
How to load and execute my .elf file from command line
I am using following command to execute the existing .elf fileJLinkGDBServerCL.exe -port 2331 -s -device STM32L462RE -endian little -speed 4000 -if swd -vdwhere I need to change to load my newly generated elf (from command line) in the above command....
Achar1 by Associate II
  • 3994 Views
