STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Error in final launch sequence: Setup exceptions
I have searched around the ST community and I am not finding a solution to my problem:I don't know what I did/changed but debugging is not working anymore! Every time when I try to debug, it's giving me this error message: Error in final launch seque...
Target not found on cubeide
I'm working with a stm32 nucleo H723ZG board. Until yesterday everything worked fine, I could program the board and everything worked well. When I tried to connect my board to my PC today, cubeide could not find the board when I tried to run my progr...
MSadf.1 by Associate II
  • 3811 Views
Resolved! Error in SFRs for STM32U575 in STM32CubeIDE
For the STM32U575 SFRs in STM32CubeIDE, the LPTIM1 DIER_output has a CC1IF instead of CC1IE.Also what is the difference between DIER_output and DIER_input ? And why are there bits name different ?
nicolas by Senior II
  • 2686 Views
Why does CubeProgrammer often duplicate HAL drivers?
I am using STM32CubeIDE on MacOS. I am finding that very often, at least every other build, CubeIDE duplicates a bunch of drivers in the HAL driver folder. When that happens the compiler throws a bunch of "multiple definition" errors. To fix that I g...
Debug multiple .elf files
Hello everyoneIn one of our projects we created a bootloader and the application. Both projects are located in a separate workspace in the STMCubeIDE v1.10. My goal is to setup the GDB debugger in a way, that I can start the debugger from the bootloa...
DZimm.9 by Associate III
  • 4414 Views
