STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1706 Views
STM32CubeCLT 1.21.0 released
  • 645 Views
Resolved! How to use the arduino string object in Cube IDE?
Do someone know how that we can import the Arduino string object in Cube IDE or how that i can make such object myself? I can't find any files about the construction of such object in arduino files(on my computer).
FLuba.1 by Senior
  • 5093 Views
Resolved! Why do i get Device not found in STM32CubeMonitor
I am using a custom board equipped with an STM32G473 controller and use ST LINK V2 .Recently, I decided to explore the usage of CubeMonitor for the first time. While the YouTube videos I watched provided clear instructions, none of them mentioned any...
_legacyfs_online_stmicro_images_0693W00000bjs45QAA.png _legacyfs_online_stmicro_images_0693W00000bjs4PQAQ.png _legacyfs_online_stmicro_images_0693W00000bjs5IQAQ.png
sde c.1 by Senior II
  • 3384 Views
Resolved! How to access mutexes and semaphores generated by STM32CubeIDE FreeRTOS integration from another file?
I'm using a mutex to share the I2C bus between an OLED display and an EEPROM. I'm using the IDE to generate the FreeRTOS configuration and tasks initialization (freertos.c file). I have an external file where all the LCD writing occurs. How could I a...
Dolence by Associate III
  • 2970 Views
bug: STM32CubeIDE build failed after Project->Clean
2019-05-28Windows 10 64bit CubeIDE Version: 1.0.0Build: 2872_20190423-2022 (UTC)Project had been compiling+linking fine.Restarting the IDE does not help.arm-none-eabi-gcc -o "cubeide-rtos-spi1-uart1-a.elf" @"objects.list"  -mcpu=cortex-m4 -T"C:\Users...
Sking.21 by Associate III
  • 6803 Views
Resolved! How to replace GUI action with command line?
I'm writing initialisation script.Project repo is cloned into my empty workspace.At the moment the user must initialy run STM32CubeIDE select empty workspaceCall File > Open Projects from File System ... > select Folder and confirmThis action is what...
DrDro by Associate III
  • 1525 Views
Strange behavior of IDE (modifies my code)
Hello!I have a weird problem with IDE.I have defined a structure which aims at initializing a menu item.This structure contains a few items including an opcode to be sent to an FPGA.The name of the structure is panel_config_item.Then I have declared ...
PG.1 by Associate III
  • 4690 Views
