2019-09-21 9:26 AM
I was thinking that it would really useful if there was a ready to use Raspberry-Pi computing module look alike STM32MP board which could be used in development of user applications.
The reason is because although ST has designed MP series to be optimized for 4Layer PCBs, the cost of 4 Layer PCB manufactoring yet is much higher than 2Layer ones. And also most of the times the PCB layout for MCUs and MPUs must remain the same around the chip. So why not provide a pre-made module for prototyping? and also if with a resonable price for production
The module could contain an MPU + SDRAM + Flash and all the side requirements. It would bring out all the GPIOs out with probably 2mm or 1.27mm header pins (and not like RPi way which requires a DIMM socket which is not so common and usual)
2019-09-22 11:28 PM
there is already plenty of 3rd party modules based on STM32MP1 series.
Some partners are listed here https://www.st.com/en/ecosystems/components-and-modules.html?querycriteria=productId=SC2287$$1=*STM32MP1*&aggOrder=0%7C1%7C2%7C3%7C4#products
But you could also search on your favorite browser for "STM32MP1 SOM" or "STM32MP1 SIP", list is expanding.
2019-09-22 11:28 PM
