STM32 MPUs Products and hardware related
Major issue with eMMC 8 bit
We are currently experiencing a major issue with eMMC on our custom boards using STM32MP153CAC. Our boards are booting normally with 1 wire mode, but as soon as 8 wire/bit mode is enabled, it starts to bug out.Here is the description of the problem f...
JOhn1 by Associate III
  • 9029 Views
  • 5 kudos
Resolved! Purpose of board ID field in OTP
Hello,U-Boot has an stboard command that writes a board ID into OTP (word 59 on STM32MP15x lines, word 60 on 13x lines).TF-A displays this board ID if a device tree label "board_id" is present in the bsec node.Could you please explain the purpose of ...
[Urgent] Looking For Description of STM32MP157F-DK2 HAL and low-layer drivers PDF
Hello all, good day I hope your Christmas season is going well. I'm looking for a pdf document equivalent of the PDF that is attached to this post that gives description for STM32MP157F-DK2 HAL and low-layer drivers or a HAL API Manual/Programming ma...
STM32MP157C kernel 6.1 nand not working
I have developed a custom stm32mp157c board with a nand IC as storage using the FMC peripheral. This has worked fine with kernel v5.15, but I am trying to upgrade to kernel v6.1 due to driver related issues of the ethernet switch. However I can't see...
SLitt.1 by Associate
  • 4221 Views
