STM32 MCUs Wireless
ctrois by ST Employee
  • 300 Views
Ouadi by ST Employee
  • 4117 Views
Resolved! How to implement custom PAN ID for Zigbee in STM32WB55 MCU?
Hi, Our product uses 2 x STM32WB55 MCUs, where one as Server/Coordinator and the other one as Client/Router for Zigbee.  However, our customer prefer to use customized PAN ID or Extended PAN ID so that more controllable and traceable by their applica...
Phang by Associate III
  • 518 Views
Resolved! STM32WBA55CGU6 Availability Inquiry
Hi,I hope you are doing well. I am currently developing a project based on the STM32WBA55CGU6 MCU. The hardware design (PCB) and firmware have been developed and validated using this device, particularly relying on its BLE capabilities and STM32_WPAN...
Resolved! STM32WB07CC: unable to obtain the wakeup source.
Hello, everyone,I am currently working on a project using STM32WB07CC. During the design of low power consumption, I found that when waking up the MCU from the deepstop mode through the wakeup pin, it is impossible to obtain the wakeup source by acce...
xxyyhhmm by Associate II
  • 335 Views
Low RF RSSI on Duty Cycled Reception
Good day, I am currently working on the development of an IoT sensor node product based around the STM32WLE5CC MCU. The product needs to be able to wake up from sleep on reception of a LoRa RF message. I have attempted to accomplish this by transmitt...
Shaunus by Associate
  • 339 Views
Resolved! STM32WB5MMG - cannot change device name/model
Hi,I'm working on a project with your STM32WB5MM module, I managed to enable ZigBee and connect to the network, but I'm having trouble changing the device name, it keeps identifying itself as default value (STM32WB).ZigBee Stack: 1.24.0FW Type : FFD ...
