STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
How to use B-L072Z-LRWAN1 LoRa®/Sigfox™ Discovery kit for US915Mhz Frequency? And how to see the downlink data?
Is there anything to change in the firmware "STM32CubeExpansion_LRWAN_V1.2.0"? If there, then where, what and how we need to change?I am using my laptop to configure using COM port for this device. So how can I get confirm that any data has been rece...
GBehe by Associate III
  • 2195 Views
Resolved! Should I Download All Wireless Stacks?
Hi,expert.I am a beginner who started using STM32WB.I am trying to download the wireless stack using STM32_ProgrammerCLI.exe and command prompt while reading UM2550.I understand that there are seven types of wireless stacks:・stm32wb5x_BLE_Stack_fw.bi...
ota-s by Associate II
  • 1613 Views
Resolved! Unable to understand TSC connections in STM32WB
Hi Sir/Madam,The Sensor Capacitor (Cx) is not connected in the below mentioned. Can you please provide clarity on the Cx connection with MCU.While configuring the shielding in TSC using STM32CubeMX, it is asking to configure Cs(Sampling Capacitor) in...
GShai by Associate II
  • 2759 Views
LORA End_Node
hello, Please be kind to me as I am new to this. I have a B-L072Z board.Use the End_Node program to communicate with the lora gateway, I found that the data transmission interval of the terminal is 10 seconds. I can reduce the time to 7 seco...
Yxiao by Associate
  • 696 Views
Migrate from expansion boards to anothere
Hi, I want to use i-cube lrwan stack for my hardware, I use stm32l151cb+sx1276. I have tried to use STM32L152RE-Nucleo and modify it. I did it for the microcontroller side and have modified pin and peripherals mapping. but I can't change radio expans...
Iot_king by Associate
  • 1904 Views
