STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4119 Views
Stm32wb55 clock settings
I created a simple BLE peripheral project by CubeMX with the clock setting below.HSE=32 PLL M=2 N=16 R=8 SYSCLK=32M system clock mux=PLLCLKEverything looks right and even the BLE sniffer receives the advertisement broadcast. However, the cell...
uouox by Associate II
  • 1883 Views
Resolved! Tx Timeout on LoRa
I have made a custom PCB with the Murata CMWX1ZZABZ-091 module. When I try running the LoRa End Node or PingPong example (for LoRa Discovery kit B-L072Z-LRWAN1) , I get "Tx Timeout" on UART. The GPIOs and UART are working fine. How do I solve this?
BT.1 by Associate II
  • 1331 Views
STM32WB55 FUS update issue
I just received STM32WB55 Nucleo pack. I'm going through the instructions in Projects/STM32WB_Copro_Wireless_Binaries/Release_Notes.html.All going fine until I get to step 4:0x20030030 : 00050300 : FUSv0.5.3 => Must be updated using STEP 5.Next I ru...
GPS Development Tools STEVAL-STRKT01 LoRa IoT tracker
Goodday, would you mind advice me pls if this module GPS Development Tools STEVAL-STRKT01 LoRa IoT tracker can work standlone powered with a battery.. i need to track an hobbyists drone and my per car. which program on smartphone or pc can be use?
DChai.1 by Associate
  • 1240 Views
Resolved! STM32wb analog voltage referrence and VSSA
Hi thereI am currently developing a product and i would like to use either stmb32wb55ce or stm32wb55rgI have done most of the softwaredevlopment on the nucleo board with stm32wb55rg.I am a bit stuck with the analog world on this MCU.I would like to u...
HSpre.1 by Associate III
  • 2064 Views
