2020-02-10 8:33 AM
Goodday, would you mind advice me pls if this module GPS Development Tools STEVAL-STRKT01 LoRa IoT tracker can work standlone powered with a battery.. i need to track an hobbyists drone and my per car. which program on smartphone or pc can be use?
2020-02-24 7:45 AM
Hello @DChai.1 ,
Based on its description on ST web site, yes the STEVAL-STRKT01 is designed mainly to be used with a battery:
-Amel
2020-02-24 9:24 AM
Good day, its not a problem use it with battery, how i can set it to make it work with out a LoRaWAN gateway?
i wouldlike use it as tracker and check it with an app on my smartphone and browser on my pc.
Waitingfor a kind response
