STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
LoRaWAN FUOTA
Good day I am having many troubles with implementing FUOTA on my Dev kit. Firstly, I have downloaded the STM32Cube_FW_WL_V1.3.1 firmware. When i edit the script files to build using the latest cube ide (1.19.0) the build fails with many errors. I the...
HKhan.4 by Associate II
  • 1067 Views
STM32WL55JC1 – HSE clock not starting
Hi ST team, I am working on STM32WL55JC1. I am trying to enable the HSE external crystal oscillator, but it never starts.In firmware, I configure RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; and set HSEState = RCC_HSE_ON. After enabling...
Sjain by Associate III
  • 1051 Views
Resolved! Using acceleration sensor at LoRa communication.
I am using NUCLEO-WL55JC1 to use LoRa communication. And I add acceleration sensor of LSM6DSOX to this board and I want to get  acceleration data while communicating LoRa. But I could not get correct acceleration value. And I could get correct accele...
machi by Associate
  • 766 Views
STM32L031F6P6 and LoRaWAN with sx1262
  Hello, I designed a board based on the STM32L031F6P6 with an sx1262 chip, and it worked well using the driver https://github.com/Lora-net/sx126x_driver for LoRa transmission. I'm trying to send LoRaWAN signals, but I'm having trouble finding exampl...
RTC Alarm B Configuration
I am using stm32wle5jc ( LoRa Wio E5 mini board) with stm32wl FW stack. I tried lot ways to implement the RTC Alarm B (in BIN, MIXED and BCD mode). But is stops entire LoRa Process. How I fixed that?
