STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4119 Views
Resolved! How can I reset the P-Nucleo-WB55 to original demo firmware?
TLDR: Is there a simple way (or at least clear step-by-step instructions) to reset the P-NUCLE-WB55 back to the firmware it was delivered with?Full:I have a P-Nucleo-WB55 and am trying to develop a project with it. I ran the "Getting Started" demo on...
AClif by Associate III
  • 7905 Views
  • 17 replies
Error: fwdelete Operation Failure! Please, try again
Hello I am using stm32wb55 nucleo i am tring to delete the firmware but it shows errorC:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=SWD -fwdelete   ---------------------------------------------...
Ra.1 by Associate II
  • 11381 Views
  • 36 replies
TIM interrupt, sequencer, SPI_SCK
Hi!I am using P-nucleo WB55 board to develop BLE application. 1 I use TIM2 to generate a interrupt where I use SPI to read external ADC data. However, I found that the time period between SPI SCK signal and rising edge of TIM's PWM is varying. as sho...
ZWH.1 by Associate II
  • 3621 Views
Resolved! STM32F446RE Setting Frequency with RFM98PW LoRa Module
Hi Everyone!We have two RFM98PW LoRa Modules and we successfully can communicate with these modules from more than 9 kilometers. But when we change our frequency from 434 to about 433.663 we cannot communicate very well. It just *****. Using these Lo...
TEngi.2 by Associate
  • 2634 Views
Resolved! Debugging Issue
Hey guys , I am trying to program custom stm32 board using stm32lorwan module using stlink v2 pins. I have configured debugger as followed.Can you tell me debug configuration?>>Connect to remote GDB server , port no 61234>...
NBhar.1 by Associate II
  • 1374 Views
Battery Service Notification on BLE
We are using the STM32WB5MMG in our product.To inform any client about the battery level of our device we want to implement theSIG Battery Level Service.After configuration through CubeMX, the Service is visible and the value can be read.However, how...
MWält.2 by Associate II
  • 1116 Views
Resolved! STM32WB55VGY6TR hci_reset section isn't initializing
I made my test codes on nucleo(32wb55) and it worked.But i have a problem on My Custom Board.I try Cable Replacment application on my board, but my sw isn't pass "hci_reset" section on "ble.hci.le.c"...When I look at the crystals(HSE_32Mhz and LSE_32...
Sadik_A by Associate II
  • 2281 Views
