Hi,There is confusion with NUCLEO-WL55JC frequency range. Maybe 2 distinct Web pages should be considered for NUCLEO-WL55JC1 and NUCLEO-WL55JC2.Board page: https://www.st.com/en/evaluation-tools/nucleo-wl55jc.htmlFrequency range indicated: 150 MHz to...
Hello,I am currently testing Bluetooth LE communication between two STM32WB5MM-DK boards. For the test, I am usingthe data_throughput example, which I've adapted from the P-NUCLEO-WB55 software package.According to the official datasheet for the STM3...
I'm developing a BLE central application on a NUCLEO-WB55RG board using the P2P_Client example as a base. I'm facing an issue where I can successfully pair with a peripheral, but the bonding information is never saved to non-volatile memory. Keep in ...
Hello,I am looking for guidance on how to share the CRC peripheral between two modules. For instance, in our application we are using the BLE stack (for example, following this: https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WBA_BLE_STM32CubeMX#...
How can I get the stm32wl5moc hardware design reference ? I searched in the datasheets but there is no hardware design reference. If anyone have an information about this kindly let me know.
Hello We would like to evaluate your STM32WBA55G and nucleo-WBA55CG boards for a project. So we have several questions:Is it possible to stream BLE audio between two STM32WBA55G boards by taking the sound from the Mems microphone and streaming it to ...
If I use STM32WBA65I-DK1 board, by enabling or using UAC (USB), can I stream multiple audio files for auracast application, like each song for each channel or subgroup.
I’m developing a Zigbee end-device app on STM32WB55 (Zigbee_OnOff_Client_SED), following ST’s Zigbee guide, but my debugger keeps showing “Target is not responding, retrying…” . I disabled low power (CFG_FULL_LOW_POWER=0 / CFG_LPM_SUPPORTED=0), set C...
Hi,I am try to STM32WBAG-DK1 PBP source example and try to create multi-channel and stream the data through it. Like in each channel, each language. I got stuck where to modify the code.Could anyone please support the issue. Thank you
Hello,I download STM32WBAxx_DFP 2.1.0 in https://www.keil.arm.com/packs/stm32wbaxx_dfp-keil/overview/ There seems no FLM drivers available to program OTP and OPT zone.
