STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
Resolved! sigfox credentials.zip problem
Hey guys. I'm trying to collect the sigfox credentials through the website https://my.st.com/sfxp and once the download is done,the file is corrupted and I can't extract it.How can I solve this problem?
Resolved! STM32WLE5CC HSE32 TCXO input
Greetings!I'm designing a board using STM32WLE5CCU6 MCU and decided to use a 32-MHz Clipped Sine Wave TCXO instead of a crystal for the HSE32 clock.I have a question regarding the additional circuitry between the TCXO and MCU, is an AC coupling capac...
DTomi.1 by Senior
  • 7971 Views
LoRaWAN StopJoin - what is this?
The LoRaWAN middleware End-node (lora-app.c) includes a "Join Switch" mechanism set up around the StopJoinTimer, the OnStopJointTimeEvent function, and the StopJoin() task function.The StopJoin function appears to be used to toggle between ABP and OT...
STM32 MCU
I have programmed the STM32 MCU as per the document (https://github.com/Seeed-Studio/LoRaWan-E5-Node/tree/qian) However, I'm not getting any response in TTN network. kindly help me resolve it.
STM32WBA52 Serial Port Emulation
Hello,I am developing a Bluetooth application which can communicate with Android phone emulating Serial Connection. On previous device we used our own Bluetooth Classic module with SPP (Serial Port Profile) using RFCOMM (Serial Port Emulation) and we...
DLich.3 by Associate II
  • 5289 Views
Resolved! Enabeling USB and BLE on STM32WB55
Trying to enable both USB and BLE at the same time I encountered difficultyThe USB failed to run.I encountered the following ticket: usb-device-does-not-work-when-starting-ble-stack-on-stm32wb55 which had an example attached to it.After trying severa...
Resolved! STM32WB15CC update application with OTA
Hello,I'm writing an application running on Windows and Linux, using Qt to update STM32WB15CC application.I have read AN5247 document and implement it, but my Qt application never receive the last Reboot Indicatatione ( characteristic uuid: "{0000fe2...
FWX by Associate III
  • 3305 Views
