STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
[BLE] User Description Descriptor for a Attribute
I would like for my services and characteristics to have a user readable string name.(when someone discovers them)How do I set that name in the descriptor of the attribute?Is there a convention on how the descriptor need to be set so devices will sho...
DS.4 by Senior II
  • 1729 Views
Bluetooth communication issue
Hi, I am using STM32WB55RG board. When I started working on the board, I did not upgrade the FUS and the wireless BLE stack. I just simply flashed my firmware hex file through cube programmer and it was working as expected(basic ble write and notify ...
Resolved! Problem activating the wireless stack on the STM32WB5MMG
I have a problem with code that uses the STM32WB5MMG.Everything was working on the device, the BLE was appearing perfectly, and I programmed everything that needed to be executed.I set up a GATT server with its services and characteristics, everythin...
DnCrv by Associate
  • 1449 Views
Resolved! Use TIM1 output pwm with STM32WLE5CCU6
Hi all, I'm trying to use TIM1 with CH1 and CH2 to output PWM signal on PA9 and PA8 with RAK3172-SIP. Here is what I've tried :       /* USER CODE BEGIN Header */ /** ****************************************************************************** ...
SBaro.11 by Associate III
  • 1609 Views
